SLP Clutch kit with Magnum Force Weights for Polaris Boost
T
trdehmer
Maybe 50miles on them....
Comes with extra inserts for more adjustability in mass.
Clutch kit new sells for $474.65
Asking $250 and can ship.
SLP Power Shift Clutch Kit for 2023+ Polaris Indy Patriot Boost VR1 – Stock / Stage 1 / Stage 2 – 0-9k’ – 41-551
This kit is designed for Polaris 850 Boost VR1 models in stock form, SLP Stage 1 (muffler), and SLP Stage 2 (muffler and head) at 0-9,000′ in elevation (or anyones elses tune). It includes all the components to make your sled perform at its peak.
This innovative patentened (US Patent #11739836 and Patents Pending) weight utilizes a slingshot effect to transfer the Polaris Boost’s impressive horsepower to the ground with precision using our industry exclusive mass profile. Its design delays initial shift, allowing the turbo to spool faster and then shifts aggressively, loading the engine and creating more exhaust heat. This improves boost function and generates more usable power quicker.
The way that we have distributed the mass within this weight’s design is the secret that creates the improved shifting characteristics. At the tip of the weight is a protrusion we call the Launch Tube. At rest and in low speed modes, the mass of the Launch Tube is below the line perpendicular to the clutch. The mass located in this area reduces the initial shift force of the weight while the turbo is in naturally aspirated and low boost mode, yet applies that mass as added shift force when it shifts above the perpendicular plane.
This revolutionary new technology replaces the need to use engagement grinds on the weights and extremely high spring rates that are prone to loss of tension and breakage. It also places the appropriate shift force on the belt at all times, proving to be a far superior clutching solution for these Turbo sleds.
