It is moved forward from the stock location. Its close but again, just parts of the little details to keep the balance right when liftingFts mounts in same hole location on ice age rails
They currently have a 2.6 powerclaw on an Alpha skid(i should have taken a pic). I bet they have a 3.5 pitch on twin rail also.Great review CO. Now we we needed to get the two elevate kits side by side. Sounds like the Alpha kit works well too. I called Ice Age Friday to ask questions but no answer and my voicemail hasn’t been returned yet.
If cat comes out with a 3.5 track for the twin rails that would be sweet. It’s crazy the traction the alpha track gets.
Interesting stuff, you guys have got me thinking that maybe I should think about buying an elevate kit for my clutched, piped 2015 with the dropped chain case and a TKI belt drive instead of picking up a 2019 Alpha One?
I emailed back and forth with Ice age today and they said on a Pre-Ascender Proclimb, if you have the narrowed front end (36") from 2016 and newer, and you have the extended chaincase from the 2017 Mountain Cat. You can indeed mount the Elevate kit on your Proclimb.
It just so happens that I have both on my 2015.
Here's Ice age's response to my question: "You have to have the drop and rolled chaincase and the narrow front end for it to work. If you made those modifications to your sled, you could run the Elevate, but without them it doesn't work."
My response was: "I did indeed add the 2017 Mountain Cat longer chain case with my TKI belt drive kit and I did swap to the 2016 spindles which gave the narrower 36” ski stance. Would it work in this case?
Ice Age's response was: "Yes sir, you'd be good to install the kit then".
This questions probably already been asked but I have a 18 with iceage bomber rails already, would like to try just adding the spindles to see if it makes much difference. Cant see the same rails only being tipped up a little more making that much difference. Suppose they'd sell just the spindles?
