I also noticed the 18’ mountain cat dove. That was the biggest reason I didn’t go with cat this year. It’s frustrating when you have to slow down to almost a complete stop to pull it out of a dive.
The alpha does it as well but it’s very easy to correct. Just lean and it comes out of it. Overall the alpha reminds me of a Doo as far as ease of riding. It’s just much more predictable and easier to keep in a sidehill.
Guys, we are super excited to roll this product out and get it in consumer hands. I will try and go through and touch base on most of the questions/concerns.
Overall Performance Goal
The second we rode the new 18 cats last year we knew cat finally had something. The Ctec motor coupled with the clutching and track system puts impressive power to the snow. The sleds get on the snow and move like nothing else. The fist thing we noticed when it was sitting in the shop next to the axys and g4 is how low and squatty it looked. The sled handles well in stock form but it still left us wanting more.
Hundreds of miles and piles of parts in the scrap bin later we have the Elevate Kit. Bringing the front end up 2" tapering back to 3/4" of lift in the rear has allowed the sled to show what its really capable of. The extra height helps the sled roll around more in deeper snow making for a more fun and less 'planted' feel. Having more height has also increase the angle you can sidehill before "paneling out". This was especially noticeable in our late season testing in hard spring conditions. You can now lay the sled into the hill and it just hangs there instead of trying to push you off. (see axys vs pro, xm vs t3 comments above) With the increased height getting the nosecone and panels so much higher out of the snow we now are plowing less snow allowing the sled to float on top with reduced effort. Our spindle is fully engineered (not just spacers bolted on) to ensure more strength from all angles even with the 2" taller base section. The spindles also include steering stops, this helps eliminate the possibility of bending tie rods all the time. You do not lose any steering angle because of this.
Approach angle/skid
We spent a TON of time tweaking and modifying on the approach angle and how we handled the drop in the rear. Obviously cat has the best approach on the market and the sled gets on the snow with ease. We DID NOT want to ruin this. The rails have a fully customized bend for this application to keep the approach as mellow as possible. We also remounted the front track shock and limiter strap allowing us to get more travel in the front portion of the skid. This helps the sled handle bumps on the trail much nicer. And obviously one of the biggest skid gains is the proven strength of our IceAge rails.
Balance
I see a lot of guys trying to jerry rig things or wanting to only do spindles and drop the skid. If it was this easy we would have done it this way and made a cheaper kit. Maintaining the proper balance of the sled and skid setup is paramount. You can VERY easily make the sled handle far worse then stock. After hundreds of miles and a pile of parts in the scrap bin, we can assure you, this is a fully developed system not just some bolt on widgets.
Specs
Spindle angle - Stock
Spindle height increase - 2.1"
Spindle weight - 3# 7oz (3oz heavier then stock)
Steering geometry - unmodified (same tie rod clearance to a-arms)
Height all added below ball joint - Stock shocks/geometry to fit any a-arms.
6061 T6 billet construction. This is a massive billet part.
skid is dropped .75" in rear and 1.2" in front.
Rails design is unique to the elevate kit
Custom bend profile
increased front track shock travel/stroke ( ~.625")
Wider ribs by ~50%
7000 series aluminum, much stronger then OEM.
If ur lazy, Alpha's are worse down hill.
Fall right over.... look like an idiot real quick.
[emoji12]
As much as I love the Alpha, I do think the elevate kit with an alpha track would be a killer setup as well. There is nothing wrong with the Alpha. It’s a beast, the funnest sled I’ve ever road, easy to ride, but in certain situations you have to be on your game. It’s super forgiving at times but can also get pretty wild. I am having to tweak my riding style/position and it’s going to take more time to adjust. But in my limited 200 miles this is what I’ve noticed.
- I’m still over riding in certain sidehill maneuvers, one of the biggest areas I need to adjust in riding style/position. Need more time to and it will feel more natural.
- As said above you cannot get lazy when things get more technical.
- It climbs like crazy but is a wheelie monster. At times that is super fun other times it’s to much. Again needs a change in riding position and getting comfortable with. The lockout flat works. Would be awesome to have the electronic version so you could push a button on the fly. I’m certain that is the future and likely will be on the top 2020 model.
- I have no issues with the trail ride, smooth or whooped out crap. I’ve been on both and no issues. I will add that I’m not a trail boomer rallying corners and all that stuff.
- On sidehills it does like to make its own track. It holds a great fresh track line and has a wide sweet spot. Still struggling a bit following my buddies line through the tight trees on a steep sidehill. Just need more time.
- Takes more throttle control when crossing tracks on sidehills. It will whip out on you wicked fast.
- The motor and clutching are awesome. The zuke was a great motor but the new motor kills it in every way. Yes durability still to be determined.
- The track, one word WOW....ok maybe two, AMAZING!!
- Cat was exactly on point marketing this as a purpose built sled. There is absolutely no doubt about that.
After all that do I have any regrets snowchecking an Alpha....hell no!! The best sled I’ve rode to date. However just like all of them they have their pluses and minuses. For me the Alphas pluses out way the minuses hands down. I can’t wait to spend more time on it. I just wish our snow was better in MT!!!
Interesting that its been 2 months since the kits were supposed to start shipping and not a single ride report.
