Look ..adding the "FIX" kit does NOT change the rod ratio in any way , shape, or form..
Side loading via rod angularity will remain the same.. So, IF there was a rod angularity issue with the engine, the the only way to address this is to alter the rod ratio.. Please keep that in mind when people claim that it "fixes" an issue that can not possible be fixed without altering the crank!
I am not going to get on here an tell you why any OTHER kit does or does not do what is claimed..
All I can tell you is that there is an issue with the stock Polaris Piston and it can be remedied in a few different manners. Once this is addressed, then the engine should be less prone to issues. But HP claims/gains need to be validated via real world visualzation .. you know... on the snow where you can see the difference!
We have addressed chosen to address the piston issues and ALSO add some good performance inthe the process.. kill 2 birds with one stone... These results can be validated and verfied on the snow.. (no it "feels" better type validation) but real validation on the mountain.
In any case, the engine longevity has been less than stellar with the CFI power plant..
ABSOLUTELY adding more oil will help alleviate the crank issues but will do little for the piston issues.
Once this engine is "humming" it is a very nice engine to have.. Just be careful about all the "theories" of what it needs and what is actually wrong.
Kelsey
