I'll have to see how the Wossners work out for me, but I think I made the best possible choice. Obviously I have no prior experience with them, but a couple guys who know how to build a motor and ride hard recommended them. The OE piston is probably more tolerant of abuse (especially insufficient warm-up), but the Wossner is lighter, and being forged, likely to stand up to detonation better. I haven't heard of locator pin issues with Wossners, but I'm all ears if they have issues too.
I plan to have the crank trued, most likely by Dan. I couldn't find any other potential trouble with the crank, so I'm hoping it just needs a little massaging; a new PTO bearing wouldn't hurt though. It's only slightly out of spec, and the runout is well in spec, so I'm going to run it the rest of the season, but not going to chance it any longer than that. I'm hoping I can just pull the bottom off, pull the crank assembly, and send that in without having to disturb and replace the top end gaskets (again).
With regard to what caused it, @05rmksteve suggested the fuel filter, and I've got an OE filter on order. Because it's got an AXYS sock filter, and I'd read those should last a long time (never needing replacement, according to some), I didn't think that could be it. The trouble is, I've still got a bog- a little different from what I described earlier - and it would fit with the fuel filter. What it was doing last time I rode it was it'd pull like normal at WOT initially, then bog off after a second or two. Not every time; I backed off immediately and didn't push it after it did it a couple times though. The reason I think that fits with the fuel filter starting to block is because it can pull enough fuel up through mid throttle, but with a burst of WOT it's collapsing the filter, getting what bit of fuel it can from inside the filter, then dropping pressure after a second or two, resulting in a lean bog. If it's been doing that a while, it's almost certainly the cause of the failure. Could be something in that tank of gas blocked the filter, or contributed to the problem. I've got a spare set of injectors I'll clean and check out, then swap in. I'm not sure how I never got a det warning through all of this - if it's leaning enough to cause a significant bog, it's enough to detonate - but the det sensor ohms out. Maybe something to replace anyway. The sled has lots of life left in it, so for however long I keep it, it's worth getting it all squared away. I'm definitely not taking anything for granted anymore though: it's getting regular leakdown and crank runout checks. Meanwhile, my old 600 has to be shaking its head and thinking "seriously bro?"
