You built your own trailer??I do this on my homemade 5th wheel trailer, seems to work fine. Been running it a few years now.
Putting all the comments & Suggestions together today and placing my order.
Yes, absolutely.will you post up your build sheet? are you going with a 30'?
Sorry...but I do NOT like this configuration.
I'm a purist...gotta be the other way for me.
So you are suggesting these glides instead?You may also want to have a closer look at the products from Caliber.
http://www.caliberproductsinc.com/
Superglides are great in the enclosed trailer until you have to try and get the front end of a Nytro moved around (usually during loading or unloading) and then it is not so nice.
I would personally go with low pro glides on the deck and either Superglides or Calibers GripGlides on the ramps.
We have the hinged Edge Glides installed on both the front and back ramp doors on our enclosed trailer and they have held up very well over the couple of years that they have been installed.
Do you think the extra 2 feet would have made a REAL DIFFERENCE??I had a 28' feather lite goose neck. I'm wishing I wouldn't have sold it now but when I get my new one thing I will do differently is put in a 72" drop down door instead of the 60" door I had. I would also run rolled rubber mats on the floor instead of plywood. Roof vents are a must and had 2 fuel doors. Drop down bunks would not have been a problem, other than that all led lighting and maybe go with a 30'
This is pretty much what I have in my trailer right now.
My issue with these is that with snow on them they are SLICK AS SNOT and I have slipped numerous times when not paying attention to where I put my feet. On the ramp, they are an accident waiting to happen, but even in the flat section of the trailer mine are "Sub-Optimal" at best. You Low Pro Grip Glides look like they would do the job nicely!!
And I do think your Edge Glides are great!
Trailer snowmobile ski edge glide system
An innovative accessory that provides smooth Edge transition from the ground to your trailer or ramp.
- Innovative Edge Glides Measure 5 7/8" x 8 3/4"
- Incorporates Caliber's proven friction-reducing glide technology
- Slotted fastening system allows for expansion and contraction, preventing warp
- Integrated edge for easy assembly
- Stainless steel screws install with ease
- 9" width accomodates all skis, ski stances and ATV/UTV tires
- High-Impact plastic (HDPE), guaranteed not to crack, chip, break or warp out
- Made in USA and includes Caliber's lifetime warranty
