Most belts brake due to secondary clutch pressure. If you don't have enough the belt will slip, heat up and come apart. Good luck everyone. Skidoo should be thanking you all for doing their R&D.
Miles?
Ace
OK
doo 16.7 pin/417127039 sec spring for 9-11,000'+ click 3,4 as neeeded to run 7800-7900 in the pow and 8000 MAX on the trail...
ANY elevation lower than 9000' needs goodwin heavy adj pin and said spring...
17.7 for 6-9000' click 2-3
20 grams 5-8000' click 2-3
21.7 grams 3-6000' click 2-3
24.1 grams 0-3000' click 1-2
official SHR low kit- #968 ramp, 19-20 grams for 0-3000', doo black qrs, 40, gear up 1...click 3-4, 7900-8000 rpm max
run stock muffler first....ANY can that loses RPM is junk...
these are base line weights, you can tweek if needed per sled/rider weight...BJ
Clicker dwg.
I believe that we'll see some aftermarket weight-adjustable flyweight arms for the pDrive this season... with position of the
weight on the arm itself variable.
This is the BRP factory method of adding weight to the arm... it only adds this to the mid flyweight position and is not changed in relation to the clutch with the movement of the clicker
What's the profile of these adjustable weights. Is it the same as stock. Are they good for low and high elevation?
I did however get the engine hot enough on a few pulls that the ECU started to pull power and the rpm would drop down to 7400 --7600 (only if I started the pull with 4 bars on the TEMP) it would pull here down after about 30 seconds of wide open./QUOTE]
Curious, is this with the stock muffler ?
*updated specs...BJ
yes stock muffler.
