Been following all the G4 catastrophe threads for a bit now. First of all, I don't own one. Secondly, I was planning on snow checking a 2018. So...I am going to ask a few questions. I was once a die hard Poo guy. I had motor problems. Lots of them. Which is why I ride Ski-doo now. I was one of those guys that would have gotten a belt eating 850 and also broke a bulk head. That being said, I believe those saying they are having issues. I think it's a real thing. I know the piston and ring issue with 800 Pro was a real thing. I lived it while others said it wasn't an issue and was being blown out of proportion. From what the latest numbers on the Pro 800 motor thread, the voting, I believe it has 20% of all Pro owners having issues with pistons and/or rings. So what is the real numbers of problems with bulkheads and belts? I don't know how to start a voting thread. Maybe somebody should and lets see if this really is an epidemic or just isolated. If it's real, show some numbers and maybe BRP will be lurking on this site and do something about it.
I had a 2012 PRO RMK 800 163 that I exploded and motor in 1250 miles in the first season so.
The bulkhead issues are real for sure, despite a lot of people claiming to not have issues. And needs to be addressed, skidoo is aware of it being a issue, since I've heard of at least one guy getting roughly $1000 out of his repair bill covered by Doo.
With that in mind I'd say next season there will be some changes there.
Now the belt deal is area prone. Since there are lots of folks that bought these and are riding at low low elevations. Those folks are not having the issues as bad (from the sound of things) compared to the folks riding in the mountains and or Deep Pow.
However it is real issue, I myself have 2 belts in 600 ish miles one was a string the other this past weekend was a utter explosion. Roughly 300 miles per belt. With belt temps over 200-220 degrees F. consistently, and clutch sheeve temps at 200 plus. It is no wonder there are belt issues. Combine that with the fact the motor mounts move 1-4"-3/8" forward and rearward. We stand no chance at the moment.
Changing out the flyweights for some aftermarket helps things, does not cure, but helps quite a bit.
Skidoo flat out left the clutch temp issue untouched from last spring on the demos.
(So much for 70 degree temp drop)The one I rode also had scalding hot
clutches. This needs to be addressed more than anything in my opinion.
I have been hearing that things are in the works but have no idea for sure what.
But even with the belt issues these sleds are MONSTERS, flat out rip! And are totally worth buying.
But if you are skeptical you could try the 18 Cat. From what I was told the other day sounds very interesting, motor wise anyway.
