Dan - Your work speaks for itself and if I were shopping for a 'fix kit' I would definitely send my engine your way, no questions asked.
That being said, I have had several kinematics, strength of mat'l, engine theory/design/simulation courses, and I have never heard of an engine with an offset cylinder from the crank center-line (not that I consider myself an expert by any means in anything or that it isn't possible). An offset crank center-line of any sliding mechanism would cause some very strange phenomenons, especially in an IC engine where the input force is the combustion event.. The crank angle would not be equal to 0 at TDC (piston at rest) meaning there would be significant force on the rod bearings when the crank angle is at it 0 since the piston would be traveling down during the expansion stroke (it might even be over constrained?), if the cylinder were offset on the intake side (refer to Heywood). There would also be significant side loading on the cylinder wall/piston if this were the case, which would fatigue any piston, cast or forged.
Also, 's' (distance from center of crank to center of wrist pin) would be very difficult to predict since it is dependent on the crank angle aligned with the cylinder, meaning finding the piston speed at varying crank angles would be difficult since Sp=ds/dt. Again, not trying to be a smarta** or discredit any of your work because I have a lot of respect for what you do, but offsetting the cylinder center-line from the crank center-line seems like a pretty silly thing to do from a design/reliability standpoint.. Is it possible the measurement varies equally on the exhaust side of the engine to make room for the increase in skirt width?
I do agree with many of the points you made and also agree/disagree with some of the things RKT is saying. Not trying to stir the pot in any way..
