No Tip weight?
![BoonDocker_Talon_Weights_63g.png](https://cdn.shopify.com/s/files/1/0381/3893/7479/products/BoonDocker_Talon_Weights_63g.png?v=1658437366)
Bikeman and mountain clutching in the same sentence is like nails on a chalkboard. Sick burn! HahaI also believe the BMP Snyper weights will work that they make for P85.
Will Polaris warranty this if you ride before you get the update? Since they issued a “stop ride” notice?More p22 fun, this one took out the secondary also.
The P22 incorporates a non adjustable spider that leads to an issue with a wide belt to sheave measurement. I have measured them in excess of .080”.
The sheaves will mate at the same time the cover hits the spider.
This causes a loss of belt grip that you will witness at the outer edge of the P22 in streaking.
In my honest opinion the P22 should be shelved and re-engineered.
View attachment 387996View attachment 387997
Thats good as some covers to spider had zero to 0.005" at mostUpdate on this issue:
On our 7075 Covers we have built in 0.025" of extra clearance from our cover to the Spyder to get full shift. The clutch sheaves will not touch first . Had to do somthing similar when I designed a Cat cluch cover a few years ago.
Tony, Curious are you seeing the same issues on current P 22’s?The P22 incorporates a non adjustable spider that leads to an issue with a wide belt to sheave measurement. I have measured them in excess of .080”.
In my honest opinion the P22 should be shelved and re-engineered.View attachment 387996View attachment 387997View attachment 387998View attachment 387999
