Thank you.1.969”
Set up another P85 for a friend, he is all smiles.
If your working on 850 boost weights, I'd be interested.
Im low elevation
Thank you.1.969”
I had similar results with the Arctic Cat roller bearing clutch. It just didn’t have the same tunabilty as non roller bearing clutches. There were many small adjustment issues that were hard to overcome. So I ended up going to a non roller bearing primary and different length belt. I found there are more better(haha yes I said that!)tuning options with non-roller primary clutch.1.969”
If your going to run a P85 we can get you setup now. The P22 kit is not ready.Thank you.
Im low elevation
Is it possible to machine down #15 spacer to get a better belt to sheave measurement?The P22 incorporates a non adjustable spider that leads to an issue with a wide belt to sheave measurement. I have measured them in excess of .080”.
The sheaves will mate at the same time the cover hits the spider.
This causes a loss of belt grip that you will witness at the outer edge of the P22 in streaking.
In my honest opinion the P22 should be shelved and re-engineered.View attachment 387996View attachment 387997View attachment 387998View attachment 387999
Im confused. if they both hit at the same time what does it matter. if you machine one its still going to lose belt grip isnt it? what am i missing here?The P22 incorporates a non adjustable spider that leads to an issue with a wide belt to sheave measurement. I have measured them in excess of .080”.
Think this might be why Polaris has the style of weights that they are using on this maybe? Seeing the pitting on the clutch face where it makes contact when the belt is pushed out by using EPI T76 weights. Maybe the stock weights by not pushing the belt all the way out avoids some if not all this contact wear while sacrificing performance.The P22 incorporates a non adjustable spider that leads to an issue with a wide belt to sheave measurement. I have measured them in excess of .080”.
Yes sir. My thoughts exactly.Think this might be why Polaris has the style of weights that they are using on this maybe? Seeing the pitting on the clutch face where it makes contact when the belt is pushed out by using EPI T76 weights. Maybe the stock weights by not pushing the belt all the way out avoids some if not all this contact wear while sacrificing performance.
Our thought has been so many years that the belt needs to be pushed out to a certain depth, but with the self adjusting tension maybe this is the way engineers want it. If you think about it, knowing how turbos were always finicky and breaking stuff not uncommon. How would you bring one to market that wouldn't always be in the shop and loose any profit the company made in the warranty period? For sure you want it running well, but you don't want it running peak efficiency to eat parts. I'd turn down the boost a bit and mess with the clutching. Owners can mess with that and get peak efficiency from there, but it will be out of their pocket, not the companies.
This is why I think Polaris purposely built and setup this clutch this way and don't really think they will offer anything different on the 23 boost or 900r. Power and potential is there, it's just up to us to tap into it at our own risk. Tapping into the performance of the machine I think your right in tossing the P85 back in. Guys flashing the ecm and twin pipes with stage1,2 kits etc and going all out I think the P85 at this point is essential.
EPI weigths work extremely well. Need to gear down and change springs. 120/285 primary and 160/260 secondary. See video.Anyone getting good results with adjustable weights (EPI,SLP) or are most just going with something like EPI Belly weights etc?
This is a pro rmk 165 with a cut skidoo 165 3"Nice! Watching some of the early video it looks like it spools up really quick and seems when you let off and get back into it the clutch seems engaged well. More so than having to constantly blurp the throttle to keep it engaged well. Are you running on a Khaos or a Pro trying to run the Khaos limiter strap etc?
Nice tree bang by the way. (Did you know a fairy has an screaming orgasm and a gnome watching pukes up a fresh home brew every time you clip one?) True story. Where do you think all these popup micro and home brews are coming from.
