Titanium. ?Wounder when someone will make a steel spider?
Indy Dan was working on one last year.Wounder when someone will make a steel spider?
Ive heard this kit is performing well. C&STRS, Do you have a Boost P-22 clutch set up that your confident in yet? I've been waiting to buy a kit due to wanting your setup but I'm running out of time b4 I go west again early March .
Cat has had a steel spider for a while. Spider is fine, but the rest of the clutch falls apartWounder when someone will make a steel spider?
Nice! What Elevation?Got out again and was able to dial this boost in. Tried several helix and secondary spring combos, along with multiple primary springs and weights. The stock 14-78 just dont have enough tip weight to push the belt up the primary. In the conditions we were in that day i was only seeing 45-46mph track speed. The belt was not even 3/4 of the way up the primary. I tried 74g EPI turbo weights with a a softer spring, and still not enough squeeze.
After several changes, I ended up using the stock helix with a gold/black secondary spring (175/240) and a blue primary (150/310) and 76g EPI turbo weights. Track speed held right at 50-51 mph. What a difference. Belt was pushed much higher in the primary and clutch temps dropped. Rpm dropped down to 8400-8450 instead of the 8500-8550.
I will be making spring changes as i didn't have these at the time, but i think the 155/300 primary and the black/ white (160/260) are going to be spot on. Ill be out testing this weekend and will report back next week.
View attachment 384962View attachment 384963View attachment 384964
Awesome! Input and testing like this and TRS is what makes SW so great. clutch on my friends!!Got out again and was able to dial this boost in. Tried several helix and secondary spring combos, along with multiple primary springs and weights. The stock 14-78 just dont have enough tip weight to push the belt up the primary. In the conditions we were in that day i was only seeing 45-46mph track speed. The belt was not even 3/4 of the way up the primary. I tried 74g EPI turbo weights with a a softer spring, and still not enough squeeze.
This was at 6800-7100'Nice! What Elevation?
I don't understand this at all.... The EPI weights have way more tip weight than the stock do and the belt is now running up the primary higher than with the stock weights. Also going from 78grams stock to 76 EPI and still pulling the same rpm kinda makes sense that the top end is pulling hard. I have this setup and the top end squeeze from the heavy tipped EPI weights is a huge improvement over stock.Carls cycle kit, just add epi weights to the stock setup, brings the bottom end to life, along with the on/off throttle. But lacking the top end of the stock weights. I just installed the s&c kit on a friend's boost today, see how it works next time were out.
