I don't have to worry about my lynx chain. I just shoved a rock through my front heat exchanger
can you please confirm what parts are needed? I don't know enough about the drive shaft connections to be sure....what in the G5 stays and what in the 22 needs to be ordered to put it back together with a solid shaft?I am aware of what parts are needed, I did the solid driveshaft swap already.
I can assure you the photo of my sled is not some regurgitated interweb pic.....chain tension was also adjusted with the cover off so no endless turns and over tightening here. I have seen two more exploded cases first hand on the mountain since mine went. Truly mind-blowing.Looks to me guys are sharing the same picture over and over and trying to make the problem look bigger than it is ?wonder if he got up to the recommended amount of adjustment turns ?
This is unreal I can’t believe brp hasn’t recognized this issue publicly. There’s no chance I’d purchase another skidoo until this problem is addressed. I’d be scared to take one out to the backcountry
I called in some big favors and was able to locally source a set of HYVO gears and chain plus a new chain slider. Swapped them back in on the hill at -23C and then rode it out. There is significant grooving to the inner case under the lower gear and also slap marks on the cover and upper inner case. However, the case still holds oil so I was very luck. I was just coming out of a big downhill line went to turn around just feathering the throttle at slow speed when it let loose. In another 30 seconds I would of been full pin up through the trees and would rather not think about what would of happened if it broke then......I believe he was being sarcastic.
Did you get warranty? What was the outcome?
Curious if you had the hitch pin on the adjuster bolt through the hole so it cannot back off or if it was “around” the adjuster bolt like it comes from Doo and is shown in the manual?Add another failure to the list… g5 expert turbo 165. My chain broke yesterday and ruined both cases. I adjusted my chain tension after every ride. I’ve never seen a chain stretch so much. The chain snapped and then broke out the bottom of the chaincase and cover.
I’m 230 lbs and ride pretty hard. I did not have these issues with my 20.5 turbo or my 21 turbo. The non-hyvo chain and gears cannot handle the power.
My wife also rides a g5 turbo 165 and her chain isn’t stretching but she only weighs 120 and does not ride as aggressive.
I have a feeling that some of the failures are a loose chain due to the adjuster backing off under the right conditions. It could happen in a matter of seconds at the right vibration frequency.
Having that pin around the adjuster never made sense to me, put mine through the bolt from day one on my 22.
Curious if others have had the failure with the pin through the hole. ??
