Nice welding helmet sir !
I have one too
Gus
I have one too
Gus
Exept for running out of argon things were going well. I can't get over how fast that little bottle empties, guess I'll get a bigger bottle monday. I made the carb pressure equalizer bar and half welded on for now. I can't get over how easy this stuff is to make. WHO WHOOO!! can't wait to see what a boosted 440 feels like on a 300 lb lay down mod.
I hope you used stainless for the bend into the turbo, or some thick mild steel.. it doesnt like the heat and tends to fail realy fast.. cracking is so much fun.
looks to be a fun sled though, good luck on the rest of the build.
Tony.. by all means post it here too.
i'm sure many of these guys as well as myself would like to keep up with your evolution of turboing 2 strokes as well as learn the ins and outs of the cats..
gus
Just read trough the thread. This info is giving me good ideas for what i can do with my old poo 01 gen2 rmk 800.
(Been used as a backup sled for the last couple of years.)
I have som questions..
-I have a Walbro external fuel pump. Its rated to 67 gph. Can I use it?
Prolly it might even be too big....you need about 35-40 gph at 40-60 psi what is the number on it?
-A friend of mine has a GT2871R turbo, can i use it?
Prolly depends on housings,but that's the one often used with 800
-Is using 3 power jets, one right after turbo and one in each carb the way to go for fueling?
Based on what I have seen Gus say, you only need the two in the carbs or air box. There are other theories however. When you use one in the tube, I believe you will also need to use a hobbs switch.
-I guess I need to get the head machined. I ride at 800ft-4600ft.
Not sure maybe to run low boost and pump?
-Can I run it on premium pump gas?
See above, but it prolly would bring a bigger smile with higher boost and race especially at your ele.
-Will i have problems with the electrical system if i run both fuel pump and oil pump?
As lom
No as your stator is rated for at least 150 watts you will prolly be fine. You may have to give up some lighting or warmers?..
I have tried to google and find projects that describe the building steps, but
cant find any. Any tips for links?
Man you found it right here.....LOL
Hope you guys can answer these carbed turbo noob questions.
