no lag issues,, forget that with a ball bearing garrett.
ar is to big. drop to .8's and be good to go to 30 psi.
comp on th eold 700 was around `12 or so, squish was horribly wide.. for booost its a poor design. re dome it.
The reed cage warrpage is due to charge heat primarliy and the clamping method too. lean backfires dont help them as they are weak in that area also. they just suck for the application
double v cages present the face of the petals at to FLAT an angle. the charge backflows and that is the issue, closing tension and full open tension are bad, but total flow area and flow volume is even worse..
just google a TSR reed program.. then you'll see the differences in flow and pressure drop.
HO cage/boot assy from the o4 is the good one.
Gus
Gus
