Papa, most that I have talked to run a straight helix. Like 46 or 48 on the 800's running 12-14psi boost.
Thanks devil. Finally starting to get somewhere.
U all have a great holiday/merry xmas
Are you using a fuel pressure guage? If so you can run it on a stand or lift and verify your fuel pressure is rising. It will rise before boost so you can get it to rise pretty easy on the stand.
Into the fat part of the pipe. Exhaust pipe. I am talking about the boost reference port on your fuel pressure regulator. It should go to your pipe.
thanks for paying atttention to me and the sled, they do tel you what they need once you know what to listen for..
I miss something... what is that advantage of having this in the pipe over the airbox???? reaction time?
Amen to that... we have yet to look at an egt or A/F gauge on mine... tuned all by feel and sound.
I don't run egt or A/F. I never look at guages so why have them.
Along with what Voodoo said, pipe pressure also is higher than boost by a couple psi.
Since I have chased electrons around most of my life, I am a guage nerd and have them all.....LOL. I used Gus's technique for the fuel pressure. And of course I have a fuel pressure guage on the bars.
I set the reg for 2-3psi at idle by the time I have engagement pressure is up to 5psi at 7psi boost my fuel is hovering around 14psi. Either the exhaust backpressure in my system is high (7psi at wot) or the reg is not truely linear. I figured my pipe backpressure would be about 5psi above intake, but looks like 7psi?????????
PS: Merry Christmas everyone!
Hey Papa,
If I'm reading all the other posts on O2 correctly and base on my observations with mine. I think you are lean. Seems that you should be down around 12 to 1(on a turbo two stroke) for a safe mixture.
Hope this helps.
Hey Gus,
I knew there was sump'n I was missin......and I used to be a whiz at math, now I'm just a whiz.......LOL
Blocking open my exhaust valves made a huge difference. Boosting real low, like 5000r's. Still a bit fat on the low end. Not sure if I will ever quit monkeying with this thing.
Didn't notice any negative from blocking the exhaust valves open. The low was as good as it was before.
How did you block the valves open? The idea of making boost at 5g's sure sounds appealing. Is it something simple you can do that is easily reversible?
Thanks
wes
