Do you think it is necessary to put the plug in under the bypass cap?
No. I just put the cap on and put a gates powerclamp on it (was only a regular hose clamp first) and it does not leak.
TSR
The skidoo thermostat will open sooner then the polaris stat but does not shut off the bypass circuit til 155'f.
So you have not completely fixed the problem, the skidoo stat will flow more coolant then the poalris.
This kit fixes the issues for high hp turbos and hard snow conditions keeping temps downs and HP up!
http://www.terraalpsracing.com/product/polaris-cfi-800-2008-2013-performance-kits
The bypass disk is connected directly to the thermostat plunger.
Usually the bypass closes soon after the Thermo "cracks open" and the separate spring on the bypass allows the thermo plunger to move even after the bypass disk is resting against the housing.
I'm confused here as well.
There is pics on the Terra Alps facebook page showing the stock polaris stat,
The bypass valve or disk as you called it doesn't close til 155'f on the skidoo thermostat
The bypass is fully closed at 120'f on the Terra Alps stat kit flowing 300% more coolant then the stock polaris stat.
This so called $28 fix will cost more then 28 dollars for the avg joe and still does not fix the problem. but to each there own.
LH..the Doo plastic housing is molded over the T-stat... not removable.
The storm t stat lower housing is no longer avail.
It looks cool... I wonder what the thermostat itself looks like inside.
BRP did have some problems with their early thermo housing and bypass. New moldings have fixed the problem. As relayed to me from a rep.
I understand it cost more than $28. Retail for the housing is $28, that is why I posted a $28 upgrade.
Here is my cost for the parts. I just went through my invoices.
BRP T-stat $18.63
BRP Tee 4.12
7378 Hose 4.56
8205 Hose 9.19
42925 Clamp 1.97 ea.
42934 Clamp 3.11 ea.
660-1696 Cap 3.21 for 2
I don't have a price on the smaller powergrip clamp.
Is this not a cheap fix?
93 storm housing. When I disassembled I found the thermo had separated.
The 2003 XCR housing should work. The thermo from 96-03 was a 120* stat. part#7051017. The top housing fits from 93-03 part#5130942. The bottom housing changed for MY1999. 99-03 bottom housing part#5132025.
