Has anyone checked to see what the flow rate difference is between the stock Polaris system and the BRP mod system?
Just looked at Terra Alps website. TA claims stock Polaris at 11.3L per minute and BRP at 26.05L per minute
MH,
Good catch. I tried the Evans coolant in the stock configuration with/without a thermostat. It doesn't work in the Pro. In winter temps the Evans gets to thick in our tunnel coolers and will not pump. I had many discussions with John Light at Evans about this. Their engineers are looking for a fix. It may work with the e-tec housing.
TRS..
Which Evans coolant were you using and what kind of low temps are you considering?
When did you talk with John?
I've had good luck with it, and researched it well...
BUT, My respect for your posts has me concerned with this.
MH.
TRS..
MH. .
BRP
1- 509000499 Thermo housing with internal thermostat
1- 509000372 3/4 x 1 barbed tee
Napa
4- power grip 42934
2- power grip 42925
1- 5/8 bypass cap 660-1696 1-8205 hose
1-7378 hose
Polaris
1- CT clamp 7080533
Washer for thermostat replacement 34mm OD, 27mm ID, 1mm thick
I don't believe anything will bring down trail temps other than more cooler area .
You can switch out the Polaris clamp with a shrink from NAPA for the bypass cap, part # 42922.
