2020 hardcore here that has the same issue. Bog/loads up/cuts out between 4500-5500 rpm
I would check the power valve cables first, I know mine were off right from assembly. I had similar issues at the same RPM.2020 hardcore here that has the same issue. Bog/loads up/cuts out between 4500-5500 rpm
I checked them and they were off. Made a little difference last ride but still have the bog.I would check the power valve cables first, I know mine were off right from assembly. I had similar issues at the same RPM.
Yes that is the part number for 2020. Got mine yesterday hope to put it in today and ride it tomorrowBeetFarmer, is that part number for the temp sensor for 2020 models?
Also, the Beatfarmers was one of my favorite bands from the 80's.
I am not a big believer in all the so called snake oils out there, but I do know Seafoam works awesome. I have used it in diesels and gas engines before with great results. Thanks for the report back , I have been suspecting injectors as my issue last year also.I had checked mine and they were still in spec (I adjusted last year after some clutching issues).
Oddly enough, my sled seems to have cleaned up a bunch. I question whether my injectors were sticky or something. I dumped in a can and a half of sea foam in my gas tank two weekends ago and have had almost no misses since on 4 days of riding and almost full tanks of gas each day. I rode this weekend in 3+ feet of fresh, deepest snow of the year and the sled only missed a couple times when sled was totally submerged in snow and intakes were covered (which makes sense) - and that was only from a full stop. Plenty of times when I was wide open making sharp pow turns, the intakes were totally covered and the sled never missed holding WOT. Didn't have any of the multi-grabs of the throttle with absolutely no response like I did before. I pulled apart my clutches to confirm all was well, etc. - it remains a mystery for now, but I'm going to tell myself the "magic" Sea Foam saved the day once again lol.
I am interested to here if the Seafoam helps or not.Update changed the coolant temp sensor and still have the bog. Talked to my dealer yesterday and they have a 2020 with the same bog issue as mine 5000 to 5800 rpm. They are thinking it must be related to injectors. I might try some sea foam and see if that helps.
I had a Diamond S Titanium can on mine and changed it to MBRP. I think MBRP runs a little better. It’s definitely louder which I don’t like. Hopefully the sea foam will make a difference.I was wondering what you found. I couldn't wait around to hear what you found, so I too ordered a new temp sensor as well just to give it a try. I will also dump a can of Seafoam into my tank before my next ride. I also swapped exhaust cans to see if back pressure changes things. Going from a BDX/SSI Titanium can to a Diamond S titanium exhaust can.
I have one if you need the Ohm readings varianceI don’t have service manual. I ohmed the old one and got nothing. New sensor should be showing up any day.
Thanks but i put new sensor in and it didn’t change a thing.I have one if you need the Ohm readings variance
Ohm the sensor to make sure it is or is not the issue.Thanks but i put new sensor in and it didn’t change a thing.
Would you send me the ohm reading variance? I will try and check it out this weekend. ThanksI have one if you need the Ohm readings variance
Here is per the service manual...sure is pointing to the rpm range where people are having issues.Would you send me the ohm reading variance? I will try and check it out this weekend. Thanks
