Both my 18 and 19 never sputteredMines sputters a bit around 5000rpm. Did the 19's do the same? The crisp bottom was one of the selling points on this sled. Mines out of break in.
Did you have to remove the hood to check yours?Good to hear, I checked mine and both were to short and not the same. I have not tested since adjustment but expect the same results as you.
Its easier to do that way, but you may be able to withoutDid you have to remove the hood to check yours?
Thanks, going to have to look into it some more. Reminds me of my 2010 m8 (not as bad though). Was hoping it was just break in. Have roughly 180 miles and 9 hours. Ill start with some fresh plugs.Both my 18 and 19 never sputtered
Sent it
You should be out of break inThanks, going to have to look into it some more. Reminds me of my 2010 m8 (not as bad though). Was hoping it was just break in. Have roughly 180 miles and 9 hours. Ill start with some fresh plugs.
I did have the hood off. It may be possible to check them with out removing the hood but it would be alot more difficult and twice as nasty to adjust. I would not recommend to perform this task with the hood on.Did you have to remove the hood to check yours?
Did you get this cleared up? This is how mine is acting. I’m at 11.1 hrs now, put in a fresh set of plugs, and checked the APV valves. Still have the symptom.Mine is stock with under 2 hours, it has an issue in the same rpm range. I would not call it a bog rather erratic throttle response. It is just not smooth when going slow or slowly adding throttle. Before and after the 4000-5500 it is smooth as it should be. I am going to get through the break in and see if anything changes.
Mine is working good just got back and we ran from -4 to -20 C, 2000 to 8000 ft of elevation and not a hiccup. The only thing i noticed was an elevated idle 2600 after a hard pull, I just waited a few seconds and it normalized to 1700 and then i would shut it down. It started first pull every time but one, that one i gave it some throttle on pull three and fired right up. I believe this engine need a full hard pull to start you cant get away with a half ass attempt.Did you get this cleared up? This is how mine is acting. I’m at 11.1 hrs now, put in a fresh set of plugs, and checked the APV valves. Still have the symptom.
Had mine do this few times when riding on it’s side and getting close to 1/4 tank of fuel or less. I think it’s sucked air in the fuel.My 18 has started to have a bog or hesitation around 4000-6000 rpm I thought maybe it was just not getting air but it just starts to sputter really bad for about 5-10 seconds and then I just let off and it seems to clear itself up but it sucks because it has caused me to get stuck! I have 870 kms now and only has been doing it on deep days and the last couple rides, also have foamed taped around my intake and siliconed my entire airbox since new so dont think its snow being sucked in! Ill check mt apv cables as well and maybe try changing plugs, does anyone know off hand what plugs are needed?
I just put 10.9gal in my 19, i didn't have any bogs or any sign of not getting enough fuel, other than the gauge flashing on E.Had mine do this few times when riding on it’s side and getting close to 1/4 tank of fuel or less. I think it’s sucked air in the fuel.
My 20 take BPR9ESMy 18 has started to have a bog or hesitation around 4000-6000 rpm I thought maybe it was just not getting air but it just starts to sputter really bad for about 5-10 seconds and then I just let off and it seems to clear itself up but it sucks because it has caused me to get stuck! I have 870 kms now and only has been doing it on deep days and the last couple rides, also have foamed taped around my intake and siliconed my entire airbox since new so dont think its snow being sucked in! Ill check mt apv cables as well and maybe try changing plugs, does anyone know off hand what plugs are needed?
I have a diamond s titanium and had a bdx intake. I put the stock intake back on and it didnt help. Mine still bogs, i kinda want to try one of the tunes out there and see if that helps.Any of you bog guys running a can on your sled? Low fuel level can cause issues as well, the 3 smart valves can sometimes seem like 3 stooges lol
