C
What if my chain has not needed to be tightened in 538 miles should I be concerned ?
Depends on what chain you have
if the chains are stretching because of slop in the coupling, you’ll still have that even with a new chain or did you order the TKI fix?Just verifying level, it’s like a tiny bit on the chain case oil each ride. The tensions what is most notable. I’ve ordered the proper gears/chain that was supposed to come with the 23’ turbo, and will report back what happens after I install and ride. Would suspect less chain tensioning and hopefully solve problem as others have found.
I havnt installed anything, still stock. But my plan is to install the TKI to fix the slop. And install the proper HYVO gears/chain to prevent the chain failure. When i searched the part # for the 53t gear my sled comes with, the sleds that come up are all NA sleds, with the exception of one turbo. I’d rather play safe with the parts that are listed. One guy I’ve chatted with installed the gears off his 21’ turbo after ordering a new 23’ chain because original chain failed on the mountain. The new 23’ chain he ordered did not fit the gears that came with his 23’ obviously. Since then he hasn’t had to tension chain every ride. Not sure if he also did the TKI solution or just the proper HYVO stuff.if the chains are stretching because of slop in the coupling, you’ll still have that even with a new chain or did you order the TKI fix?
You should keep that to yourself. We can't have talk like that around here.What if my chain has not needed to be tightened in 538 miles should I be concerned ?
450 miles on my expert 154, Noticed a mild vibration in the drive axle the last few days... Dissassembly coming. tki driver kit on order.This is what happens to a chain that has bin adjusted 5 times on a 175 turbo
Absolutely! I hope everyone is. This should not be an out of pocket fix.I hope guys are putting warranty claims in for this and not just changing parts.
Will the hyvo setup fit on a 23 driveshaft?Hotrod sled shop has hyvo kits in stock they are team/venom parts that are very good stuff . Fact is the china chain in the china5 just can’t take the hp of the turbo R and the movement of the coupler and from poor fitting bottom gears .
Since I have put a 2022 track shaft and hyvo gears in my 23 I haven’t had to adjust the chain once before this I was checking it every day
Maybe concerned you are riding it hard enough? Haha. I’m sensing sarcasm in your comment though..What if my chain has not needed to be tightened in 538 miles should I be concerned ?
From what it looks like and the part numbers showing different on the parts breakdown for some and yet some are correct. I would bet there was not enough supply HYVO chain and they outsourced and it’s biting customers in the butt. My lynx uses a different chain and I have only tightend it once barely. My dads xrs has taken a few turns now. Are these chains with a different part number a HYVO design but not a BorgWarner product? Or are the gears not a correct p/n as well? And if it’s not a HYVO and not a silent chain then what is it? Might take my dads apart and take a look at what I find. I ordered the tki for my sled, but might have to put it in my dads if the lynx are not having issues with this.i should pull my chain case apart and look to see what’s in there my sled is like 581 on the serial number how many did they build and are they all the same?
you can pull the plug off the top of the chain case cover and see what numbers are on the top gear and the chain.i should pull my chain case apart and look to see what’s in there my sled is like 581 on the serial number how many did they build and are they all the same?
Agreed, More importantly, these failures need to be documented.
When i went to my dealer yesterday it seemed like nobody had brought all this to their attention. My salesman was already aware of the TKI solution. The non-HYVO parts were NOT on their radar. It appears a lot of this chatter blew up this weekend on their internal forums though. Now that this has been brought to their attention, they told me they needed a sled that had actually failed (have my buddy who's chain failed submitting a claim) in order to start a warranty claim. So its a tough one because if people are preventatively replacing parts, there is no claim to start since nothing technically failed....Agreed, More importantly, these failures need to be documented.
