Hi - Figured I'd add in more real world examples to show that this is not an isolated event/ just 'forum rumors'. Although, I will say that the gen 5 turbo is a SWEET sled and the power/ride feel is awesome! But this weekend after chatting amongst a few of my immediate buddies, I can report:
- My buddies' 23' turbor chain blew up at 330 miles, stranded him in the Whistler backcountry and had to leave sled overnight. (No pics yet)
- I saw the issue and took apart my own chain case today on my 23 turbo r to find slight wear on the inside chain case. I'm at 200 miles
- My second buddy also took his 23' turbo r chain case apart to install the TKI solution today and had much more wear on the inside of his chain case, at 350 miles
- We (along with 2 other 23' turbo r users who have not taken apart their cases) have all experienced the 'abnormal amount of tensioning' we need to do for our chains after each ride
Upon our chatter, I spent hours digging into this, between reading forums like this, facebook, and other outlets, it appears there are some common theories:
- The issue could be the two piece design on the drive axle, solved with TKI's solution: https://tkicnc.com/product/g5-chain-case-retainer-w-speed-sensor/
- As stated very early in this thread, the parts received (53 tooth sprocket, 21 tooth sprocket, and chain) do not line up with what the parts finder online says.
- According to the parts finder,
- The 53 tooth sprocket should be:
504153997 <<<Error I looked at the wrong 23' turbo model. The correct on the 23' turbo parts fiche is 504154167.This should match up with 21/22 summit x expert fiche part #
- The 21 tooth sprocket should be:
504153910 <<<Error I looked at the wrong 23' turbo model. The correct on the 23' turbo parts fiche is 504154188. This should match up with 21/22 summit x expert fiche part #
- The chain should be:
504153397 <<<Error I looked at the wrong 23' turbo model. The correct on the 23' turbo parts fiche is 504153759. This should match up with 21/22 summit x expert fiche part #
- What I actually have on my sled:
- 53 tooth sprocket: 504153998
- 21 tooth sprocket: 504153910
- Chain (mine also reads 'LB537' as caper11 called out on page 1. Although the part # is not stamped on it (or I could be blind..probably the latter)
So my question would be, we can eliminate the slop TKI identified with the TKI solution, but if we do indeed have the non-HYVO spec sprockets/chains, do we replace with the items listed on the skidoo fiche? Or do we skip that, and go to something third party like the this:
https://www.hotrodsledshop.com/skhygechkitf.html ? Ultimately, for me, the goal is to have piece of mind that my chain is not a ticking time failure that will happen while I'm out in the backcountry leaving my sled stranded and me two-upping back home...
