Should probably start a new thread for this but this is kind of relevant here as well.
Dan, I'm looking for your opinion. Even with the issues you have shown, u have stated multiple times that this is a great motor. This is all premature and irrelevant until/if we start to have problems, but what would you do to make this 850 "bulletproof". If there is such a thing in this industry. I only make 4ish trips a year so down time wrecks my winter. This thread has me worried, hopefully for nothing. But I have a silber kit on order and I want to have it be dependable.
yes, i realize this is comical being I have only put on 25 miles....
notice the lock ring groove in the relation to the groove in the bearing from
extreme in to extreme up to where the seal stops.
If your sled was assembled like photo #4 the end is near.
Dan
more pics coming.
ok, here is the finish bottom-end.
Notice the photo with a straight line to the wheel to bearing sitting dead center
and notice the huge amount of clearance.
everything is all good with the bearing centered.
Dan
It's flooded. Hold it to the bars and pull like you would a carb'd sled.
Obviously. If it was mine it would be fixed already.Could be normal.
If it starts.
There is some troubleshooting you can do.
Bare with me on this, but I think you'll be able to follow what I'm walking you through here. This might take a couple days of trial and error and patience.
Is it flooded? That's been happening during the break-in.
If the case and cyls have too much fuel, it can be hard to pull over...but it doesn't yet mean it's a bearing issue. So check on the flooding issue and rule that out.
Some people are cleaning up the flooding by taping the throttle to the bars and letting it sit for a few hours to clean out/evaporate the fuel in there.
I've heard of people unplugging the injectors and then trying to start it. It helps from adding additional fuel during the flooding process.
If it IS flooded right now and you clean that up and are eventually able to get it started...let it idle up through a full heat cycle. Don't touch the throttle yet. Let it get up to 145 degrees. If it shuts off on it's own after it warms up, then the bearing could be swelled enough to shut the engine off.
IF that's the issue, and you let it cool down overnight to let the bearing shrink back down, it should start again.
If that works, it COULD be the bearing.
Any indication of the root cause of failure was?
But pull it a few times with the key off first. With key on it keeps pumping fuel.
No, just the guys with 850's.....So are we all screwed? Lol
