Snowest Pod said its an average of Khaos and RMK - Unsure if the coil changed on either but would guess noWhat is the rail profile for both then now?
I'm curious about that too. If I pick up a used sled I might try that 3.25 out if it can be done at a decent price. I did notice that the spec sheet only shows one weight, doesn't list different ones for the different track lengths anymore like years past.Is the 325 a direct swap for a 2023 series 8, no mention if drivers are different. Going to be a tight fit.
Just read that the cooler is changed so can’t run a 325 on older sleds.I'm curious about that too. If I pick up a used sled I might try that 3.25 out if it can be done at a decent price. I did notice that the spec sheet only shows one weight, doesn't list different ones for the different track lengths anymore like years past.
Just saw on someone's Instagram, it is the same weight as the 2.75" trackI'm curious about that too. If I pick up a used sled I might try that 3.25 out if it can be done at a decent price. I did notice that the spec sheet only shows one weight, doesn't list different ones for the different track lengths anymore like years past.
That's too bad, is it changed on all sleds for 2024?Just read that the cooler is changed so can’t run a 325 on older sleds.
It is not. About same weight as series 7.Just saw on someone's Instagram, it is the same weight as the 2.75" track
My sled was to Washington in 3 days after marked shipped.That a good point on the shipping. In the fine print it says: "Shipment means the eligible sled has been loaded on a carrier and has departed for delivery to the dealer."
How long were most people waiting once their 2023 said shipped? Was 1-2 weeks from that date pretty normal or was it more like 2-3 or longer? It says "departed" so not just loaded on a trailer and parked in the back lot waiting for a truck to pull the load but actually on the road to the dealer.
You're right, I read it wrongIt is not. About same weight as series 7.
Did anyone see if they announced what the stop ride release for 2024 will be?
I read if you go over 50 mph for more than 4 seconds a warning message pops up and it logs the excessive speed into the sleds computer.Can you mountain ride above 50mph with series 9? The boost runs 60ish climbing!!
