Plasma is the way to go, I don't happen to have one though. (Been out of town for 4 days.)
Kool...I can borrow one from work. I have my footwell vents to put on and my Better Boards should be here next week....I know what I am going to use.....
looking good ron, how much heat tape did you use on your hood?
If not check with a local Heating/AC Co.wonder if an Ace hardware would have it...no hd here
Ron,
I've melted a side panel after removing the aluminum guard on that side..
Took a fall after a long hard pull and seld rested on the side panel... pushed the side panel against the muffler and melted thru... I had heat tape on there..
This year I'll be running a better heat shield material on there... those sidepanels are abit pricey!!
This stuff does not hold water and is good for direct contact at 1700 deg F... cuts easily and has the adhesive already on it!
Link to the 24" x 21" Insulation
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DEI%2D050501
Link to the 48" x 21" insulation
http://store.summitracing.com/partdetail.asp?autofilter=1&part=DEI%2D050502
DEI insulation material
Is there still a weight savings using this product over the stock sheid?
935.... Post up some pix already!!!
