08 RMK 700 clutch kit
what would be the best option for a clutch kit for my sled. im a heavier rider at about 220lbs and primarily ride low elevation. looking to give up top end for more snap and bottom end. track is 155" and only mod is MBRP can. another question, if i do go with a low elevation kit what would happen if i do go to the mountains once a year to ride? thanks guys
I run at 1000 ft and run stock secondary spring and helix but the epi high engagement primary. I run 64 weights at home and 60 weights at blue river valemont elevation. I also run 18 43 gears very snappy. I'm 260 lbs same sled. I use an ultimate belt which is stickier if I was using polaris belt I would use 66s at home 62 in hills,
