T Motion install write up 1
Hello every one I got the T Motion all mounted up in the sled today other than have to slide it back a bit to allow for more rear axle adjustment.
I`ll start off with a Lists and as many part number of parts I purchased that I started with and had to gather as I was putting this project together, First I start with ordering the T Motion kit from my dealer Mac`s Cycle here in Clarkston wa where I live they let me order it and make installments on it to have it paid for before it arived which I did , a week before the first arival date and after a few anoying arival date set backs comes in. When I ordered the kit I figured I would get a bunch of measurements from an XP Summit and mount the kit into my stock Rev rail, (which can be done pretty easy) but I was browsing thru Ebay and found a set of 08` 154 XP Summit rails for $60 shipped I couldn`t pass that kind of deal up and a set of new Black Hyfax`s for $38 shipped so I decided to go the easier route and mount the kit in those rails. So I ordered from the dealer the Front plastic runner tips for the rails.
My sled has a 159 Track on it so I knew it would take some measurements and figureing just where I was to set the and where to mount it since I was going from a Chassis that has a VE Drop and Roll in it that is 1 3/4down and 1 1/4 back with the Jackshaft in the tunnel , and since after the D&R I couldn`t bolt the front arm exactly where it needed for the equal skid setback and down to match the D&R, cause of a tunnel and running support bracket that had a reinforcement rib on it in the exact spot just where I needed to drill my hole I could of removed it but would of hindered the strength of the front of the running boards so unfortuneltly I had to mount the skid 1 1/4 farther forward ahead of this rip or crese in that bracket , but it set in a good enough position and had correct adjustment of the rear axle with stock 7inch wheels, Now I have to configure where to drill and correctly mount a 154 skid with 8inch wheels and has different length front arm that set in a totaly different positioning in the rails than the Rev and the CTC went from 32inch to 30inchs, also wasn`t sure if I had to relocate the VE drop bractet, This skid comparison and figureing was the most dificult part.
I will explain all what I did in next Post. With Plenty pics
I knew I could interchange some parts from my or a Rev rear skid and some parts could adapt to the Tmo kit or at least I hoped I could, So now I needed to know if the Rev Shocks would swap over to the XP skid, which would of been a big purchase if they didn`t and after extentful research on Here, Dootalk and about every rev and xp shock listing on ebay I could come across I found that the Rev and XP Summit front and rear shock were or are the same length. and have the same diameter eyelets, bushings and bolt sizes so here is the research I ended up with and the shock comparisons..
Front shocks 13inchs eye to eye
Rear shocks 17 1/4inchs eye to eye,
I found a bunch of 17inch shocks and wasn`t sure what the difference would be but after installing the kit in the rails the last week I found the Rear shock Cannot be any shorter than 17 1/4 the 17 lacks just that much to install and if you try to force it on it messes up the whole movement of the rear scissor assembly action since It ties in with the bottom rear of the front arm which the bottom of the rear shock actually mounts along with some aluminum strut bars that go from the bottom of the front arms rocker assembly up to the front postition of the rear scissor assembly , completely different design than the Rev.
So I took the 05 Rev skid out of my wifes 97 Summit I have been putting together for her and took it apart to see what I could use from it.
I also learned that the Tmo kit skidoo offers it an actually intented as an upgrade kit for an xp skid so there are parts that need to be purchased to complete the assembly unless you have an XP skid assembly to start with then its a directcomplete bolt in.
So for parts I had to order, I found on a Microfiche Here
http://www.shspowersports.com/default.asp which other than my dealer is where I buy all my OEM parts, great price alot of times I show print outs from here to my dealer and they price match or get pretty darn close. and don`t charge me shipping.
Here is the XP parts I had to list according to the Microfiche
# on Microfichs breakdown pictures
Tmotion kit 860200763 $326
XP 154 rails / Ebay $60 shipped
163 Hyfaxs black/ Ebay $36 shipped
(cut to length)
#9 Front rail runners / x2 503191137 $4.73/ea
shorter bolt thru bumpers and rails, washers and nuts reused
from rev skid
"Front Arm:
#30 Axle bar / x2 503190643 $7,50/ea
Will have to purchase new 2 new bolts and washers that go
aluminum strut rods and axle bars front and rear, the instructions
of the kit this is easily seen
#25 Bushing /x2 503191262 $7.50/ea
(x4 outer arm bushing for mounting bolts same as rear arm
"Rear Arm:
#38 Cushion, /x1 (bushing upper) 414936000 $5.92
Lower shock bushing is discarded
#34 Axle bar /x1 503190643 $7.50
Same as front arm
One of the new bolts needed explained above is same length and
goes thru outer aluminum strut rod and this axle bar to
#24 Bushing /x2 503191262 $7.50/ea
Outer upper scissor assembly same as outer front arm
"Rear Axle:
#30 Spacer /x2 503190428 $3.55/ea
Platic spacer between inner wheels and rails
#22 Tensioner straps /x2 503192814 $3.55/ea
Adjuster bolt & nuts are reused from rev skid
New shorter bolts needed for tensioner strap
(harware store)
"Parts Reused from Rev Skid:
Front upper inner cross shaft down inside center of upper arm between
bushings that the skid mouting bolt threads into.
Front shock, upper bolt
Front shock lower mounting shaft all washers and spacers over shaft,
bolts and washer inside and outside of rails
(Tmo kit comes with new steel lower shock shaft that all spacers,
washers each side of shocks are suposed to go over and came with new
thru bolt that is smaller than the hole in the rails that you are supposed
to install a sleeve over the bolt and slides in the rail cause the hole in
rails is bigger than the new supplied bolt) I installed the complete Rev
lower shock shaft assembly for weight purposes cause its all aluminum
and the bolt from the Rev shaft are the same as the xp rails.
Front cross shaft and outer bolts that limiter strap wraps around
(Tmo kit came with new steel shaft and bolts I installed the Rev Aluminum
one for weight purposes)
Rear upper inner cross shaft down inside center of arm betweed
bushings that the skid mounting bolt threads into
Rear shock, upper bolt and spacer (I purchased a new spacer listed in
above list)
Rear springs
Rear spring plastic rail mounts, bolts, inside washers
Outer aluminum wheel collars w/ set screw in them, outside of top wheels
(don`t tighten set screw to tight or till mounted in sled, it sqeezes the
upper arm shaft and locks the bushing from moving.
Bolt, inner and outer washers that go thru lower scissor assembly piece
along with the pipe or tube spacer that goes over the bolt and inside
the lower scissor assembly
Bolt, washers,nuts from Rev plastic rail ends installed in XP new rail plastic
ends
Screw and nut that goes thru Hyfaxs and rails
Ice Scratchers (the rails I purchased had previous holes for scratchers, cool
I didn`t have to drill just bolt on, but did have to discard the big washer
that went between the scratcher spring or rod and the rail wouldn`t fit
Will start the rest of the install in the next Post.
Thanks, Wildcard
