Hello, Here are some pic from today on installin My Snow Eliminators and Finishing my side panel mods, still need to get some 2 Cool Vents for the Knee area for hot air release.
Here is a pic of the Crappy!! stock running boards, also in this pic if you look at the running board support piece you`ll see there is not Boot Loop that bolted in, also ground out the Rivet nuts out and smoothed up the bulky welds around the outer curve of the support.
Snow Eliminators, see where I cut another set of square releaf holes or notchs to move the Eliminators back.
Board cut out, this is alway a scary part cutting and hoping you don`t slip or screw up to bad, Lol
Eliminators all installed will be adding another square relieve hole in the boards ahead of the Eliminators and the stock rubber flap that goes under those holes.
Here is the pic of the rear lower corner of the panels trimmed and reshaped to match the inner suport piecs, this allows your feet to get a couple more inchs farther forward on the outer part of the boards, I also like this mod when setting and haulin Azz on the trail whipping into corner you can get your boots out farther and slide back farther with more leg to waist support and can hold you lower body better when leaning and laying off the throttle and into the brake into, or comin hot on the throttle out of a corner
This time I did this trimming I was in more of a hurry and didn`t get as smoothe and neat as I did on my other panels but still works the same.
Thanks all for lookin and reading, please post you comments or suggestions or anymore ideas. would be appreciated.
Enjoy, Wildcard
