T
TBWdracula2003
ill never drive a half ton if theres somthing stronger to drive. the older half tons were alright because you could order them with 3/4 ton suspension but its just me i hate driving half tons
You could just go to a suitable trailer size and keep the 1/2 ton. I like the 1/2 ton since I get over 20 mpg unloaded on the highway, but you can still tow when you have too. This little Triton weighs 900 lbs, has a fold-down back door, and trailer brakes. Fits two long-track sleds no problem.
Edit: no, there's no heater, tv, sauna, jet-tub, or pizza oven.....but it beats having dirty sleds.
Whats the secret to getting over 20 MPG on the highway? I've owned two GM 1500's much like yours and I never saw mileage like that on the highway. One was a 5.7 and one a 5.3. My Tahoe is a 5.3 and before the lift the best I could do was 17mpg. It now gets 12-13 on the highway. Anyone want to buy it? Its on is way out to make room for a dodge 2500!!!
I know the air bags are more and there is a little maintence involved, but with helper springs(depending on what shape your existing springs are in) they will work good for awhile then take the shape of your old springs in probably less than a year, depending on how often you put them on load, unless you get them resprung or put new leafs in there too. the nice thing about the air bags is that your springs are there basically to keep the axle in place when under load, and once you find the right air pressure empty it will be a smoother ride when accompanied by the springs.
now they also have a new load leveler out that is basically a rubber bushing
that goes in the same place as the air bags. it's a lot cheaper and still does a good job. because you only use them when you there is enough weight to bring the truck down on to em. might be something else for you to consider too.
and as for the extreme cold the only problem you would run across is water in the air system. and you might have to add some more air when its that cold.
I drive an 07 1/2 ton hemi with lots of mods and airbags and it does just fine
Dodge is giving $9K factory rebate on the 1/2 ton and my local dealer is doing another $5K cash back. Brand new, decked out is under 25K. If this keeps on I may be driving a new 08 hemi 1/2 ton soon.
Ok, you've talked me into it, Im buying a 1/2 ton!!
Wait, I already have one?
What was the question![]()
Any more opinions?
dont get a hemi, they BlOW! i dont know if theres any other motor that they will put in it but if at all possible dont get the hemi
it's funny how in the mid 90's everyone seemed to be fine towing witha half ton. But now unless you have a 1 ton, diesel you can't haul a box of popcorn
