This 1/2 ton stuff is all fine and dandy on dry roads or flatland country. Its the pure ice, mountainous areas and narrow roads combined that tip the scales.
The majority of you have confirmed what I had already thought. I will need to upgrade to a bigger truck before I can get an enclosed. I understand that the flatlanders can and will use the smaller truck and be fine, but I travel up the ugly roads to my riding and typically the roads are always slick. Thanks for the response.
who in there right mind honestly thinks that you cant pull a 4 place enclosed trailer with a 1/2 ton. my buddies 24' haulmark with sleds weighs maybe 6500lbs with gear in it and my ram 1500 has a tow rating of 8700lbs. thats a full ton over the weight of the trailer. i've pulled that trailer all over MN, ND, SD ,WY, MT, CO. Yeah you might not be able to go 75+ all the time on every hiway but just because you can't go 100% of the speed limit doesn't mean it isn't safe.
Slow down and take it easy that 1/2 ton will do just fine
On the other hand I did buy a ram 3500 diesel last year and it does pull it like its not even there but its way more truck than you need for a sled trailer.
oh and BTW get a race car style trailer not a true snowmobile trailer they sit lower and pull much nicer behind a 1/2 ton
Disclaimer: Like I said earlier an aluminum 4 place may cahnge the whole discussion. although, they cost a lot more.
To the quoted poster:
First of all the discussion was NOT "Cannot pull" It was a discussion of pros and cons of pulling.
And it wasn't about how fast you can go.
And plenty of people in their "right" minds may agree with you or not.
And there is a size truck between you're 3500 and a 1500.
So... have you been pulling a 4 place maybe 27' on snow and ice in the mountains with a 1500? How about up FS roads unplowed? In the mountains above 9000' week after week go weather or bad????
Most people said ok on open roads etc, and no problem non-winter. I double pulled a 27' travel trailer with a 12' trailer with an ATV on it and gear. Then put two dirt bikes, 4000 watt Honda in the bed... and two people in cab with gear with a... Nissan Titan for 3 years+. Over two 10,000' passes from Pagosa Springs, Co to Silverton Colorado. and over Wolf Creek pass to points north. No problem at all.
But in deep winter cold, ice, snow, slush, unplowed roads my 27' snowmobile trailer loaded up was a hand full at times.
Thats my honest opinion and am not putting down 1/2 tons, the recent changes to 1/2 tons are amazing. Just sold mine, it was a hot rod and I loved it. But now I need more payload and a bit more towing capacity.
The poster just asked experiences and opinion. So don't blow a gasket.
The price between a new 1/2 ton and a new 3/4 with a gas engine is so close that is shouldn't be a choice issue for most.
BTW I sold my GMC 3500 to buy the Titan so I know what they will do also and we could start another argument on the use of a dually in the ice and snow.
Oh yeah, what's the Ram payload. Around 1500# right? (If you have the Hemi and 4wd)
With a 27' 4place you are still dealing with that. (look at my original post) If you want to put on load levers and anti sway and then risk tweaking your frame on rough 4wd roads... go for it. Oh yeah... wait... you're towing heavy with the 3500... Hmmm advising people to do something you're not????![]()
With the soaring diesel prices I got rid of the 2500 cummings and went with the 1/2 ton Tundra. Biggest concern at the time was how it would pull the 4 place enclosed. After much ribbing on here I am happy to say it pulls the trailer just fine. We took the 27ft trailer with 4 - 4 wheelers, a Polaris Ranger and camping gear to the Uinta's for the weekend. Instead of going 70 over Parley's, I was only able to do 60. I can live with that. Biggest concern was getting everything stopped. Added a good break controller and everything stops just fine now.
Now, that being said, I have to admit I did feel more at easy pulling that same load with the 3/4 ton. Not that the Tundra feels unsafe or anything, just the law of bigness doing it's thing.
Are you doing that on snow and ice etc??
