SWEET! build ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
would it be posible to use a mig welder ?
SWEET! build
I dont think i would ever do it with a mig welder. For one thing at least with the .5inch tube its very difficult to get perfect tube fits as I have had to notch all the tube by hand with a die grinder. So its very nice to use the tig welder with a pedal to be able to very heat to fill bigger gaps without blowing threw. Also with the pedal you can slowly taper the heat of at the end of the welds and keeps it from leaving a little dimple at the end. I just don't think you would be able to get good penetration with the mig and not have it blow holes in the tube. Also with the tig I use the high frequency start so you don't end up with scratch start marks all over everything. I am certainly no professional on this. I am just a 21 year old going to school for mechanical engineering. Its just my opinion on it from my experiences and talking to a guy I know that builds nasty asphalt sleds with chro-moly and sometimes ti chassis's.
Thanks everyone for all the comments on this thing. As I said i am only 21 years old, I am trying to get an early start on some intense sled projects lol. This very much has been an experiment for me and there are plenty of things I will do different the next time around. Also I have a limited budget being in college. In hindsight I could have just bought a VE tunnel to replace my mangled one and have been done with it, but i think i will really have something special and very unique. I will take great pride in being able to say yeah, I built this sled, the tunnel, trailing arms, radius rods, steering post and built the engine.
Sorry this was long. Thanks again all. There will be plenty more to come as soon as I get home from school again.
My motivation came from spending alot of time in this guys shop. Builds amazing stuff http://pcsperformance.com/
Only 21 whatever, you have some fab skills dude! Gonna be an awesome ride.
Thanks for sharing, keep up the good work and keep us posted.
RS
Very nice work ninjin, where did you get the Tapered Pieces you welded to the end of the control rods and the end of the trailing arms that the Heim Joints thread in to?
Good Job, Wildcard28
Awesome. Makes me want to go fire up my welder. Very cool.
Sled is looking great! The pics got me off my *** finally, as I am building up one also. I am a bit behind you (quite a bit), I just got the pieces cut to graft onto the bulkhead. I was going for a straight steer tube as well, but was going to cut the welds on the pitman arm, and stop bracket to reuse them, I think I'll just go your route now, lot easier! Keep posting the pics!
Thanks its flattering all the comments i have gotten on this thing.....sweet,looking forward to more progress...I'm impressed
What type of filler rod are you using?
If you have access to a little drill/mill, use a 1/2 inche endmill, and cut the fish mouths with that.
What percentage of weight drop, would you expect from a tube chassis, versus a stock one?
Looking good.
Looking good.
Usually its not only about the weight loss - it is but it isn't. Yes tube chassis' are lighter, but they are so much stronger as well. When I stand on mine, there is absolutely no flex in the running boards. They are so much more responsive to the touch, because they don't flex at all either. You lean and it leans - you carve, it carves, etc. The power is usually transferred a little better as well, since the bulkhead does not twist and flex as much, keeping things better aligned.
I think I dropped about 15 lbs off the chassis, but like Ninjin, I removed the oil injection, lighter parts, drilled some holes, mesh hood, etc etc etc. My sled weighs 487 lbs full of gas, ready to ride.
