K
Sorry for the delay I just got a chance to post some pic's.
If the price is right, I would take one. I hate electrical and dont want to wire up my bosch.
The m7 has 2 little case nubs on each side of the oil pump that are not used for anything so a person would have to cut down the first one on the mag side closest to the oil pump. The m8 & 1000 have two motor mount studs on the mag side also but the pump will clear them but you may have too relocate the motor mount that just bolts on.
How fast does the oil pump spin? Oil doesnt come gushing out when that is running, because I have mine oiling my turbo. Also, I am assuming the shaft has a small propeller on it to move the water? Maybe different sizes/ designs of the propellors may work?
And I think you may want a bigger cooler to help with heat transfer, it may not be the speed of the flow but surface area. It looks like your cooler is just a single run of aluminim pipe?
What size are the electric pump inlet and outlets?
What size are your inlet and outlets? 1/2"?
Let us know as soon as you get an answer, hopefully before some vendor uses your idea and marks it up...
The pump is a direct drive to the oil pump. I have my oil pump running my turbo oil supply also so the pump drives at the stock RPM. As far as the flow and heat exchanger the one I use is to a 500 snopro so if it keeps a 500 engine cool it should work fine for the intercooler. I am going to install a valve to modulate the water flow until I find a temp I want to run and then install a flow orifice and yes they are 1/2". should work.
Cheers
I hope to get some pricing soon so I can fill you all in. When I put this pump together I set up a drive shaft to run off
my dewalt 18V cordless drill and on high speed it shot out a solid stream 1/2 dia about 10 feet and washed down my posters on the wall . I know it was not a technical test but with that volume I think it will be fine for what we want it for.
Cheers
I to work with radiant heat and cooling through ground source and also do HVAC. I have been working with this set up and I totally agree with you about heat transfer. That being said I am working with parts mainly like the 500 sp tunnel cooler for cost if I want to produce these sleds and they do work quit well for this build. Time will tell just how well but I am sure I will be very pleased
