on the solenoid hose just grab a 5/16 bolt and put in the end
Look guys, any fuel controller in itself does absolutely ZERO!
The mapping is the issue, and you're in control of that.
Typically the stock sled is LEAN in the mid-range and FAT on top.
Generally the maps are RICHENED up in the mid and LEANED out on top.
Sometimes it's just a matter of fine tuning the mapping
If you still think it's the PC-5, input ALL "0"s across the screen and it's as if the unit is doing nothing.
Dragon Guy,
Just because you didn't have problems prior to the PC-5 installation, something else unrelated could have gone bad at around the same time
Two things you confirmed that are not yet done on your sled.
1) For the 5 minutes it takes, SYNCH your PC-5 to the SLED, (even if Jim didn't mention it, it is in the DYNOJET instructions) that will eliminate one more possible problem.
2) SET THE T.P.S. as outlined in the INCREASING YOUR IQ THREAD at the top of this section. T.P.S. settings are CRITICAL l!!!!!!! A sled with a T.P.S. out of spec will NEVER run right, PERIOD!!!!
3) Something that's sometimes overlooked, exhaust valves, bellows, springs, possibly gummed up, check those and after that place a small set of vice grips on the purge line hose to eliminate the possible issue of the solenoid being bad
You can do all of the above in approx 2 hours, and there's a good chance you'll solve your problems and if not, you've eliminated 4 more things.
4) You said earlier your sled doesn't run right between 3500-4000 R.P.M. and since you're RICHENING up 40% throttle opening at that R.P.M. you need to take those #'s and reduce them is what it sounds like. For a quick experiment, take all those RICH POSITIVE #'s 40% and below, change them back to "0"s and take that for a test ride.
I have also had bad results now I have a bog in the mid range and I would like to change my map and sync my sled with my laptop, but i think the pcv program will not work with a Mac book even though I have excel. Is there any way to adjust the maps with a apple laptop.
Kraven that 12 volt suggestion is great to know. I can't look at my sled because it is in the shop again (hoping for the best). So is this plug neg/pos sensative and what color are the wires. I plan on using it to get a feel for were my sled performs best. I have a throttle position I call 3/4 that that my sled will climb harder and higer and pull harder on the trial but I don't know what it really relates to in the PC-5 map. This should get me closer than just a guess to tune around.
