2nd Run with Tempaflow at 1/8 turn clockwise (4000ft)First run with Tempaflow at base line 6000ft https://photos.app.goo.gl/GtXyWCMv9nSpXWbX6
Took it up to the cabin to unload it. Pulled it a couple times and didn't even seem like it wanted to try to fire. Lifted the hood. Sheit! Forgot to turn the fuel off. So I turned it off, pulled and pulled and it backfired. Great. I know the case filled up with gas again as they are notorious for and did the day before. It did this when I remove something behind the pump. I rebuilt the pump first and then had it fill up. Empty the crank case and pull and dry the plugs and it fires right up. Pulled the gas tank to replace the seat cover, same thing. This is the third time. I know back in the day you didn't dare stop facing down hill or they had a tendency of filling the crank with gas. Odd thing is, it's twin brother, (My greazy project ultra rmk #1) with all the same setup under the hood, has never displayed such temperament. I've got another fuel pump rebuild kit. Think it might be worth a go to break it down and rebuild it again or is this just simply something that is expected and accepted for this animall?
i found all of my triple indys were finicky that way
