Isn’t the clutch taper different?Adjusted the air screws on both machines. #2 was set right or close to it with 1/2 turn. Original greazy triple was set to 2 turns out? Surprised it didn’t burn down in the time I had it. Maybe that’s why compression was 105/118/128. Course I rejetted the mains as soon as I got it home and richened the premix. Maybe that kept it from detonating earlier.
Got new fuel lines (set in them seemed like thin aquarium tubing held on with zip ties), air lines, cylinder head bolts. Lost a needle clip which should be arriving today. Replaced the jackshaft and Chaincase bearings and chaincase seal, installed a longer stainless chain tensioner bolt.
Found the wire severed to the water temp sensors that I runs into the heads. Should be getting that this week. Ordered an oil check valve/ filter that runs between the oil tank and oil pump.
Got one bolt out of the left side which is the one I was concerned about since I could not find a replacement foot rest assy. The right side is broke off too far up to get anything on it. With how hard the left side was to get out even after welding a nut then snapped off so welded a washer and then a nut to it and used a lot of penetrating oil to get it out. We decided to save the aggravation of trying an easy out on the other side since I had the $30 right side foot rest at home. Got the rivets drilled out for that and going to put the replacement in today or tomorrow.
Clutches: scored 2 p-85 clutches from 2020 axis chassis sleds from a co worker. $400 for the pair, one with 600 trail miles and the other with 0 miles. Going to disassemble and swap springs and weights over. Guy said he thinks he’s got a secondary also. I don’t think I want to mess with setting up a secondary just yet and if I did I’d probably look for maybe a car with an encapsulated roller. Loved one I had from Hi-Tech Performance on an 01 Mtn cat 800. Having belt deflection set automatically would be cool along with wicked fast back-shifting.
Well soon find out. If it is got two pro chassis and an Axis that they would work for spares.Isn’t the clutch taper different?
2020 800’s had the 850 taper.Well soon find out. If it is got two pro chassis and an Axis that they would work for spares.
