T
Turbo11T
In the picture it looked like you mounted it to the factory holes in the front so it looked as if the post may have been at that angle still although i guess you could have bored the hole at an angle as well. Another words the tubing for the bars are 90deg to the post.
Your right as your sitting on the sled left to right the post has a angle from vertical. The stock post does not allow room for this to be straight o I wish it did. Would have been 100x easier.
Looking at the sled from the side the post has gone from 40 degrees from vertical to 15 degrees from vertical.
The post angle as you sit on the sled is not a issue. The T will obivoulsy be on the sled on a flat plane. This will not affect the way that the post works. As the T will rotate on a flat plane still.
