is there any way to make these pros premixxed?
Wrong.. 40:1 is even too much. 32:1 is drowning it. I'll bet you have oil spewing out your exhaust donut.
I've owned every 800 twin Polaris has made since 2000. Even with nitrous 50:1 still works fine. If you are between 40:1 and 50:1 injector mix ratio, it is close enough.
50:1 works sure, but its not what it best for the motor. More oil means
- better ring seal
- slower wear
- more power
- cooler running
- more consistent running
- cylinder last longer
- pistons last longer
- rings last longer.
List goes on and on, I ran 25:1 on my xp carb, it never ran better, Racing Intermediate class on my cr and rm 250, again 25:1 jetted to perfection. crisp snappy no spooge.
If you understand how the motor works, spooge is a byproduct of the engine running to cold. A common idea is excess smoke and spooge is to much oil. It is a engine on the cold side of ideal AFR.
If the sled is tuned properly, carb or efi and runs at the right temp/afr you could go as rich as 15:1 and it would make fantastic power and run clean.
Next fuel fill up do the quick math to check your oil injection rate.
gallons of gas x 128 / 50 = ounces of oil needed
12 gallons of gas = 1536 ounces
1536/50 = 30.72 ounces of oil.
Assumption
50:1 mix rate.
Simply measure how much oil you are putting in the oil tank and compare figures.
40:1 could be calculated the same way, and is a very liberal mix ratio.
So much bad information on this site wow!
How do you get more power? Your BTU input from gasoline has not changed. You will not get more power unless you add more fuel and can efficiently burn the fuel to make power.
I'm not going to argue though. CRANK UP THE OILER, GIT-R-DONE... Why not just get rid of the gas all together and run it hotter than hell! Yeah..
amen.DTR did dyno runs to prove his theory. They had to hit 18:1 before it showed negatively on power. Couldn't disagree with you more but yeah there's a lot of bad info out there, lol.
amen.
I premix my toys and shoot for around 32:1 if not more. runs good, oils cheap. makes good power and the motors always look amazing when torn down.
i want to try and mixing one in the 20:1 range and see how she acts.
amen.
My 11 was +55:1 as delivered. Turned it up to ~35:1, depending on how I ride. Yes, some people do check it, not hard to do with a marker and a measuring cup. Moving metal parts like lubrication.
Smoke at start up is not a good indicator of adequate oil use, it's from a cold chamber and pipe.
I would really be interested in knowing how you're getting these ratios. 55:1 as delivered and turned it up to 35:1?? How do you know/verify this? I have seen many make the claims about knowing what ratio they're at and what ratio they adjust to but can't understand how they're determining/verifying these ratios.
Thanks, John
Thanks, John
Hmm. I'll bite one more time.
So, I measure it. Recurringly before and after changing the pump setting. First, gas to full at neck, oil full to a mark you make on the tank. Go ride. A lot.
End of day, add oil in ounces with a measure cup, to a mark on the oil tank, the gas in gals to full. Be precise (a culinary secret). Gal gas to full x 128 divided by oil ounces used. Do this every ride for a few weeks. Change your setting. Started doing this decades ago when not deleting the oil pump on mod sleds while making big jetting changes. I am an old guy but not senile, yet, and I remember how mains, pilots, needles, needle jets, air and fuel screws work and impact oil ratios.
Yep, it varies based on the day, I use more oil on deep, pinned days than harder snow days. So what, this is not quantum mechanics. It took + five turns on the oil adjust screw, screw flush with locknut, lever past the scribe on the pump. On the 11 pro, the first giveaway was using less oil than an etec I also own on the same day and conditions. It was obvious something was up, and it wasn't magic. Poo really leaned the oil out on these sleds to get EPA compliance with semi-direct injection. Just sharing what I've found. It's up to you, your sled, your responsibility if you screw it up, do what you like.
- better ring seal
- slower wear
- more power
- cooler running
- rings
Sorry, but I'm callin' foul on this whole discussion. We need an expert to tell us what turning the screw up really does. As far as I know, that screw just sets your oil at idle/slow speeds. Once you get on the throttle, the oiler is wide open, is it not? Seems you guys are just burning extra oil when idling, if you turn past the notch. Correct me if I'm wrong.
