Well, piggybacking a secondary fuel system is exactly what was tried on the E-tec turbo I was around. The issue I have with that is it totally negates any possible benefit that the E-tec type of fuel delivery might have ever had. It eliminates you ability to control fuel timing in accordance with detonation events. Basically after you piggyback onto the stock setup you have an over complicated, prone to problems throttle body injection setup. Why not just build one of those?
I was talking with the guy who actually owns the e-tec turbo 600 I was around on Friday. He thought that they had finally got the fuel controller and auxillary injector to work fairly well. What nobody could get control over was the factory ignition and injection control. So, there are a ton of different sensors all over that motor and as soon as one reads something it doesnt like it either causes the ECM to radically pull timing causing bogs in VERY bad spots or it will pull fuel. When it pulls fuel you get a radically lean condition because the auxillary injector is still adding enough for the motor to run, and you get a mid throttle burndown out of nowhere.
What is really bad is that we have to have fuel in the case to make the crank live at larger than stock output. So, we cant even just build a larger E-tec injector and let the factory setup run it. We are stuck adding fuel to the bottom end via throttle body injectors. This is not cheap in any way. Then, somebody is going to have to get control over the factory electronics. We CANNOT deal with sensors going off and timing getting jerked out of it.
Overall, this will be a huge step back for the hotrod guys. E-tec was never and has never been used to build big power. That isnt what its about at all. It is an emission tool and that is it. Not some great electronic gizmo that is going to allow us to build better turbo Doos. Not by a long shot.
Jake
