G
greasemonkey3406
Heard a little rumour that this will be on the 2027 sleds from factory.....
Hopefully they don't "legally" steal it.Next up, Polaris licenses or buys this technology from TRS/TKI to be incorporated into all future sleds!
Looking at the intake valve at the top of the airbox during boondocker breathe right install today, it's just a smaller and less robust version of the TRS power boost valve.
Stoked to try this thing out. Install was simple, just requires basic disassembly. The force turbos tool is really convenient for removing the lock nut on top of the fuel tank... well worth $25.
Yah that's a new sticker, didn't have that on mine.any insight on the y pipe springs? Just saw Toby's story. Are the OEM springs not creating a good seal?
Just put TRS valve on 22 boost and yes there something to the springs for sure as there is oil residue at the y pipe connection after first ride out. That being said that valve is the answer as I haven’t had this thing run this good ever. Spools way quicker and doesn’t fall flat on its face when letting off at the bottom end. Probably has something to do with tossing the P22 off and a TRS clutch kit in a P85 as well! Tough to tell what the real fix was. But I’ll go with both at this point.any insight on the y pipe springs? Just saw Toby's story. Are the OEM springs not creating a good seal?
We have found once you add the valve, the single springs on the ypipe do not maintain a very good ypipe to pipe seal.any insight on the y pipe springs? Just saw Toby's story. Are the OEM springs not creating a good seal?
Only an issue on the Ypipe to pipe side, or would it also be beneficial to do from pipe to turbo as well?We have found once you add the valve, the single springs on the ypipe do not maintain a very good ypipe to pipe seal.
We have added the “double up” recommendation to each screen.
Yes it’s both I ran P-85 clutching on my boost last year and it was a noticeable improvement this year I installed the valve an WOW now it’s a beast!!!!Just put TRS valve on 22 boost and yes there something to the springs for sure as there is oil residue at the y pipe connection after first ride out. That being said that valve is the answer as I haven’t had this thing run this good ever. Spools way quicker and doesn’t fall flat on its face when letting off at the bottom end. Probably has something to do with tossing the P22 off and a TRS clutch kit in a P85 as well! Tough to tell what the real fix was. But I’ll go with both at this point.
You can do both if you like. The y pipe is a necessity.Only an issue on the Ypipe to pipe side, or would it also be beneficial to do from pipe to turbo as well?
So, double up on both ends Tony?Only an issue on the Ypipe to pipe side, or would it also be beneficial to do from pipe to turbo as well?
I've had good luck with partzilla.Speaking of ordering Polaris parts... what's everyone's preferred Polaris online vendor (with all schematics) that doesn't take days to get your package out the door?
