Nothing beats the Woody's spring pullers, I have both lengths. Get the original Woody's ones not the copys.
Would possibly using a couple of loops of safety wire twisted tight or a stainless steel zip tie work better than double springs? Either way seems easier and cheaper and should prevent any separation of the pipes. Anyone tried any of these options?We have found once you add the valve, the single springs on the ypipe do not maintain a very good ypipe to pipe seal.
We have added the “double up” recommendation to each screen.
Springs are the only way to goWould possibly using a couple of loops of safety wire twisted tight or a stainless steel zip tie work better than double springs? Either way seems easier and cheaper and should prevent any separation of the pipes. Anyone tried any of these options?
Can you please explain why.Springs are the only way to go
I do the same exact thing.I’ve used paracord with good luck on the stubborn springs.
positive pressure, if that donut seal wears at all then something like safety wire would then be useless, a spring keeps pressure on the joint. it also allows for some flexCan you please explain why.
Agree, but the safety wire loop/s would be in addition to the single original spring. Also the idea would be that the wire wouldn't overpower the spring so there wouldn't be flex, it would only supplement so the spring so the exhaust couldn't push the pipe away from sealing.positive pressure, if that donut seal wears at all then something like safety wire would then be useless, a spring keeps pressure on the joint. it also allows for some flex
well you want it to be able to flex a little while still keeping its seal, the engine twists in the chassis some under load. and with that movement the safety wire twists would likely start to unravel rendering it useless. Having spent time in the Air Force, ive done my share of safety wiring.Agree, but the safety wire loop/s would be in addition to the single original spring. Also the idea would be that the wire wouldn't overpower the spring so there wouldn't be flex, it would only supplement so the spring so the exhaust couldn't push the pipe away from sealing.
Yep, I have many stretched gold springs around from the boondocker Axys days before I solely starting using the silver heat treated ones.the big thing is heat. those polaris springs at the manifold are heat treated. if you try other ones that aren't heat treated they won't last a day. my experience anyway.
So you're confirming it's best use the black springs, not the silver ones, eh?the big thing is heat. those polaris springs at the manifold are heat treated. if you try other ones that aren't heat treated they won't last a day. my experience anyway.
A big reason in this application is thermal expansion( along with vibration and chassis movement). Once the system heats up it will expand, stress the safety wire and stretch it. Once it cools it will be looser and less effective than the initial install.Can you please explain why.
ya the gold or silver lose tension being close to high heat. they work well for a pipe to can connection or mounting but not the y pipe temps.So you're confirming it's best use the black springs, not the silver ones, eh?
