Hey Guys I gotta jump in here!
Everyone is making some good points, but I want to clarify something here. OT has quoted the race manual a couple times and is correct about the whole roller/hill thing. BUT here is what the 09 book states."the steeper the hill the roller must overcome, the higher the RPM will be before the clutch shifts out." The steeper ramp makes the engine rev higher (because of that steep angle, more RPM is needed to create the FORCE needed to overcome that angle and have the primary shift out) Now at this point the pinch or squeeze is less than at the lower angle. This does not always mean that the belt is now sliping.
OT, engine RPM will drop because of more load on the track (thus more load on the engine) when leaving the trail and jumping into the powder, But altitude does effect the engines horsepower also. You will have less HP at 9000' than 3000' (unless you run a turbo or supercharger.)
Look at a dyno sheet, notice how they always state the corrected Horsepower. Thats corrected for sea level, there is a standard out there that all these dyno guys take into account based on humidity, temperature, and barometric pressure which is most affected by altitude.
I hope this hepls close the gap for a couple guys.
