R
RKT
2) Lifting the cylinder on this engine will change crank case volume which we have found to hurt performance, especially, at the higher elevations..
I have to disagree as The motor was designed as a 600 and the factory race sleds increase crankcase volume any way they can I belive the lack of volume is one of the reasons this motors not in the 160's like the rest
Lifting the cylinder on this engine WILL LESSEN Piston support which WILL increase piston wear and WILL place more stress on the skirt of the piston and the cylinder.
that depends on the piston configuration! But this JMO
So, at, say... 7000ft.... how is that 800 acting? Is it acting like a true 800 or maybe a 600?? It is all relative... your 800cc sled is really a 600cc sled at the higher elevations... food for thought...
As for the piston configuration changing load properties.. sure.. but when you already have a cylinder skirt that is too short and then you raise the cylinder.. that too short skirt gets even shorter, not longer, so there is less piston support--> everytime...
