D
Danbot
Dan, I just ran out quick and laid a caliper against my stock 144 rails & my 153 Iceage rails, if using these as a template, relocating holes on your rails will not work and here's why. On upper bracket the holes are approx. 2.6" apart, it does look like the rear part of suspension is moved back equally(but I wouldn't bet my paycheck on it, as I was just holding caliper close to holes), but where the torsion spring would have to go, PT B, you'll run out of rail to place hole, at PT C, it looks like it's been slotted where the lower shock mount would go, lastly, the rubber bump stops need to go back also, so you would have to mill out some rail. Lower RTA would be no problem but it doesn't matter at this point. So basically if budget & time is an issue, just run with what you got! There's really nothing wrong with your suspension other than the bit of trenching, leave her for a summer project?!
OK, thanks for looking further into it for me, I'm actually quite happy with how the skid worked this past weekend anyways.
