Looking good Dan, I like the helmet but its not my colors. Keep up the good work and have fun with the testing, its good to have a few people open to pushing the envelope, every little bit helps!
Also want to commend you for pretty much setting the standard(as far as I have seen) on the 900 switchback converion w/ damn good info to go with it!
Also my left upper ball joint popped apart on the trail. I'll have to dig into it again tomorrow, this little stuff is getting annoying.
What gearing?
One thing I see that may help, since she's extended to 151, you could move RTA back, that upper tunnel bracket (with two holes) is punched to accept 144 front hole, 151+ back hole, now if (and only if) you could get accurate measurements to drill out rails to move bottom RTA shaft back and torsion spring clip, this might help it float out a bit better. Maybe call IceAge mfg.? They've been quite helpful with me in the past.
