hERES mY aNSWRE hERES MY aNSEWER.....its already been proven
Ot
Ot
No he did not suggest that at all. The feeling was that the secondary set up from the factory was good. Now I did have to re-set my click adjusment on my secondary after install. I think one of my issues right now is that my primary has a new surface that I did on it as well. So it is a bit grabby at this point.
OT is right but just not explaining himself to you. If you take the arm from the center of the pivot point and draw a straight line through to the center of the roller the weight is centralized.So you have X amount of force at full shift. If you add weight to the UNDER SIDE of the arm it will increase X buy a larger amount than if you were to add the same weight to the tip, plus it will backshift better.This is what heavy hitter arms accomplish.The further away from the center line of the arm on the under side the greater the force even more, thats why the heel clicker arms would fix the full shiftout force because the arm is still being pushed up.If you look at were the roller is on these new arms you'll see all the weight of the arm IS on the under side forcing it to shiftout more than anything on the market.Those arms are a drag racers dream, I just hope it will backshift well,that is just as important in my opion.Hard to explain in such a small paragraph.
Hope this helps
I agree just couldnt understand the last sentence. Makers of these arms said it was back shifting fast at every speed thats what made me want to try them.
OT is talking about the Thundershift arms, Heel clicker arms or any other arm that you can add weight to different parts of the arm. He may be right that the other arms are great, I have no experience with them so I don't have an opinion. The problem is this thread is about a completely different arm, that's all.
I appreciate the info you and snowrdr could share red-eye. Hopefully you get some snow and can do some reall testing soon. These new arms seem very promising... as long as they can back shift. My concern is that they's get stuck up in the mid to high range RPM's and that you'll need a stiffer spring - which kinda defeats the purpose IMO.
Anyway, all I'm interested in hearing is how Snowrdr, Red-Eye or anyone else that has trid these arms makes out.
All REV, MXZ, Mach Z, and Summit Models This revolutionary weight is a direct bolt in for all TRA and TRA III clutches. These weights are made of billet aluminum and solve the age old problem of not having the TRA clutch fully shift out on the top end. It works by tucking up to 22 extra grams under the stationary pin (similar to the Polaris flyweight style clutch). The results are unmatched acceleration, and top end speed with explosive midrange. Our competitors are busy trying to duplicate this design because it works so well. Our patented leveraged arm has no compromises. It adds weight at just the right time to give you a complete solution.
Those are the ones I was more interested as well....here's a C&P from their website:
The "heel" is what makes the Heelclicker weights work. As the roller goes past 90 degrees to the center of rotation, it losses starts making less force. The Heelclicker weights have a portion of mass that rotates into the 90 degree slot after the tip goes past. This is why they work.
Those other arms you guys are looking at are just another way of getting more tip weight. Argue all ya want with OT, but he's (in essence) correct. The OLD Heelclicker system that he reffered to was a way of using Comet-style weights (Heelclicker Comet-style weights) in a TRA. That system WORKED....but you lost your TRA clickers.
exactly, of the overall mass pin+arm weight, there is much less, you could add 20 grams at 1/4 the distance up the arm and get the same RPM results, but it will shift like a turd.i think you guys missed the point, with the balancing act less
force is exerted in the swing pin and so more is left to do shifting,
not necesserly needed more weight to do job, more weight ends up in
the ramp % wise
mr mike, northern alberta
