H
On the oil topic,
I don’t know enough about 2 stroke engines to say much of anything.....other then, one would think oil should be metered proportionally to the flow/pressure of fuel consumption….yes?
Its also clear the stock oil pump has a cam/meter cable thingy that meters the oil injection proportional to throttle position.
I need to really read up on small engine applications to the level of what a design type engineer would know.
I’m also not clear on what lubricating levels/pressures/flows are needed for the crank/bearings/seals….are the bearing oil bath? Are the seals lab seals? Like I said before, its best to do some research…
At the end of the day, you don’t see threads about lack of oil on the bigger boost 2 stoke sleds also….so maybe its not that big of a deal…..but I would put money on a premix option being more ideal
