I
disco patatoe, 2860 64 ar
Best post ever!
1. yes, the smaller the core of the aftercooler the more it takes to move the amount of air needed.
ie, 12 with a minicooler may well be equal to 9 without the minicooler .
im sure that is a general calculation from auto turbo kit makers with a much larger intercooler.....no way will any sled intercooler drop 25% in pressure across the intercooler,.....but im sure BD has measured pressure across the intercooler, but im sure they wont release this info as folks will just bash it
A fixed intercooler would have its own coefficient number that is used in a general algorithm, flow/pressure would be the two integer variable numbers
The point of any forced induction system is to provide the motor with a supply of higher than atmospheric denisty air. It is the density of the air that matters not simply the boost pressure.
This is why the intercooler is great!
Great theory, works well as long as you can flow air through the IC. As Bohne stated, application and fitment become the problems...
Jake
You guys have me worried! My dealer did a spring order on several kits and I thought this would be the time to try a turbo on my 09 m8.
Our snow show is in a few weeks, I'm hope most of the kit builders will be present. After reading this I will have alot questions to ask.
I will ask this ? of you guys, I dont think it has anything to do with any kit.
The reeds seem to be an issue, everyone talks about changing them out?
Good thread, I try to read all I can on turbo's, I think there are the way to go, but the cost is way to high to buy wrong kit.
Thanks alot
