I’m not about to try to explain how the bypass valve works because I really have no idea, but the video just explains that it will keep the same hp as a stock sled at sea level (165) until you go above 8000 ft., and then the power will start to drop off but will drop off at a rate that will be 40hp above what a n/a sled would have at the same altitude. At 3500 ft, you won’t notice much difference in power. There should be a little more power, but remember that what you test drove was more than likely still in break-in mode (so probably less than what is going to be there after break-in also). THIS TURBO DOESN’T HAVE ANY ADVANTAGE OVER A NORMAL 850 IN LOW ELEVATION RIDING CONDITIONS!!! Or not enough to matter (at 3500 ft). Again, it is in a SUMMIT!! Not a sled for flat landers because it won’t do anything for a low elevation flat lander!!
If you want to understand why this is a game changer, come out west and test drive one at 8000 ft, and then test drive a n/a one at the same elevation. Then, you WILL understand. At your elevation, it has no real advantage.
