The 2011 800 Rush is at Dynotech today........cross your fingers for some good numbers..........cheers
Non EPA complaint is on the DYNO today! Wait until fall for the REAL numbers!
will we have them before snowcheck?
You have 2 days. If it is 154 hp, will you snow check? If it is 151 will you? At what point will you say no to snow checking because of an independent test in the flat lands (I live a little higher)?
@50 degrees F, 2011 preproduction 800 stock makes
143.2hp and 92.9lb-ft @8100RPM
Posted on DynoTech
After PCV tuning for max HP
150.2hp and 95.1lb-ft @8300RPM
But the 2011 800 had 10 more hp @7000 RPM than the 2010s so power through the midrange is improved...
All according to the report posted on DynoTech
Why would manufactures leave that much on the table? Are emission impacted that much vs. power with pipe design?If that's the case, why not be pleased if, for a few hundred bucks, you can have, say, 15hp more than your pals with bone stock Rush800's?
