G
geo
The other important thing about the squish measurement is the angle. Piston crowns may be different (just sayin'). I found this to be true when comparing my MNTK pistons to stock Poo.
The squish measurement should diverge (become greater) from the cylinder wall to the center. Without a least a degree difference you will have problems. Especially with too large a squish clearance.
2.5 thou. per 100 thou of squish band width is what I consider a minimum (abit more than a degree) to 3.25 thou max IMO with the larger clearances you need to run on OEM stuff (the rest of the motor).
The other thing, IMO you can not find a pump fuel in BC today that will be trouble free above 135psi cranking pressure. That's MO but I played with this for a few years including last year with this Poo. My Cat's were a little more forgiving but I rarely took them over 8000 rpm. My Pro needs to run a little higher.
At 145 last year I had to overweight the clutching to stop det (just with head and pipe)(until 6000`which leave`s out too much good riding in BC lol). This added heat (belt) and lost performance for me.
This year (porting, pipe, head, MNTK kit) I set my domes to 58 and 140 to start and had both det and poor performance lol. So poor snow and my attitude lol forced me to try again.
52 squish and 135 and it made a world of difference on my Pro with BC fuel. No det, good powerband, and never signs off on the top, on my package. These are finiky little motors.
It would be very interesting to find out from your dealer what these measurements are.
